SAP2000 API using MATLAB - Time History Analysis 3
bridgehealth
I'm trying to run an time history analysis using the SAP API with MATLAB to run several different (100s) of time history records on a structure. I've been able to create the actual time history load case itself (using SAPMod.LoadCases.ModHistLinear.SetCase) and able to change the number of time steps (using SAPMod.LoadCases.ModHistLinear.SetTimeStep), but when I try to actually change the parameters of the time history (such as input, load pattern, etc...) using SAPMod.LoadCases.ModHistLinear.SetLoads, it doesn't work. However, I can do it manually and get the information back using SAPMod.LoadCases.ModHistLinear.GetLoads, but then just trying to put it back into it doesn't work.
Please help if you have any hints!
Hi newtonthegreat,
If you define Value like this:
Value=zeros(6,1)
Value(1) = true;
Value(2) = true;
Value(3) = true;
Value(4) = true;
Value(5) = true;
Value(6) = true;
and then call "whos":
>> whos Value
Name Size Bytes Class Attributes
Value 6x1 48 double
you can see that the variable is an array of doubles because the logical (true/false) is converted to double (1/0) and then stored in Value (defined previously as double).
You could try something like this:
>> t = true;
>> f = false;
>> Value = [t; t; t; f; f; f];
>> whos Value
Value 6x1 6 logical
Now the variable is an array of logicals.
I have succesfully tried this way in methods like:
SapModel.PropLink.SetMultiLinearPlastic
SapModel.FrameObj.SetReleases
SapModel.PointObj.SetRestraint
In the closed thread
khalilalloqa asked
"Hello, where could i find the VBA examples for sap verifications?"
For SAP2000 V14 they are located in one file in the path:
[Program files]\Computers and Structures\SAP2000 14\Verification\SAP2000_Verification_1400.xls
Hi Osquru,
You are right. I just checked my previous models and I found another way of doing the same thing is to initialize as below and then assign value.
Value = logical(zeros(6,1));
for i=1:6
Value(i)=true;
end
ret = SapModel.ConstraintDef.SetBody('Body1', Value);
That's how I was doing up till now but earlier I didnt even realise how important that step was.
Anyways thanks for giving me another method and explaining it so nicely.
Hi Osquro and everyone,
Currently I am working on a model in which I need to define a non prismatic section in SAP2000. Below is the syntax that I wrote for that. I was able to get the two cross section that I am going to define at starting and ending node but unfortunately the non prismatic section is not getting assigned through my code.
ret=SapModel.PropFrame.SetISection('A','A36',20,6,0.5,0.3,8,0.8);
ret=SapModel.PropFrame.SetISection('B','A36',10,6,0.5,0.3,8,0.8);
%Both syntaxes above are working fine but this below one it gives ret=1 (unassigned value).
NoItem=1;
StSec={'A';'A'};
EndSec={'B';'B'};
mlen=[1;1];
m=double(mlen);
mtype=[1;1];
EI33=[2;2];
EI22=[1;1];
ret=SapModel.PropFrame.SetNonPrismatic('Var1',NoItem,StSec,EndSec,m,mtype,EI33,EI22,-1)
%above syntax assigns a variable section for non prismatic section defined by cross section A at starting node and B at ending node.
I would appreciate if somebody can give me some hint or suggest something to solve this.
Thanks!!
newtonthegreat
It didn't work in my machine.
Sometimes to learn the syntax of other commands, I've tried reading data provided by GET method before using SET method. For example, try the method GetNonPrismatic in a existing file, so you can see the expected arguments to be used in the function SetNonPrismatic.
But in this case Matlab just crashes.
