SAP2000 Database Access
scudelari
Petroleum
NL
Hello Everyone,
I have to access and manipulate the database data model of a SAP 2000 v17 model.
What is the database engine they use? Is it possible to access it using some other way programatically than that using the API?
My intention is simple: I want to create a plugin in which I will
1- Create a load case
2- Assign stresses and moments to each beam and/or nodes that have been manipulated somewhere else.
3- Code check.
So, the question is: how can I change the calculated loads, stresses moments of a given load case?
Thank you so much.
