I'm getting a pretty common SAP error, but I can't track down what the issue is. the model is very simple: I have a rigid member with a load on top connected to a HSS column. if I change the height of the column, the error goes away. can someone help me understand what is going on? below is a picture of my model and rigid member definitions.
Error message:
Load Case : MODAL
Element Type : N.A.
Element Name : N.A.
ZERO OR NEGATIVE MODAL-MASS VALUES WERE DETECTED DURING ITERATION, THE RESULTING EIGEN-MODES MAY NOT BE VALID - CHECK THEM CAREFULLY !! THE STRUCTURE IS UNSTABLE OR ILL-CONDITIONED !! CHECK THE STRUCTURE CAREFULLY FOR: - INADEQUATE SUPPORT CONDITIONS, OR - ONE OR MORE INTERNAL MECHANISMS, OR - ZERO OR NEGATIVE STIFFNESS PROPERTIES, OR - EXTREMELY LARGE STIFFNESS PROPERTIES, OR - BUCKLING DUE TO P-DELTA OR GEOMETRIC NONLINEARITY, OR - A FREQUENCY SHIFT (IF ANY) ONTO A NATURAL FREQUENCY
thank you!
Error message:
Load Case : MODAL
Element Type : N.A.
Element Name : N.A.
thank you!
