Brad805
- Oct 26, 2010
- 1,506
I am tired of the time to enter the plot names for each .pdf file. Using PDFCreator I can dump a plot to a specified folder in seconds, but they are not named. So long as you print them in the order you want, you can bind them into a package easily when you are done. I see there is an option in PDFCreater to add a CSharp script. Is it possilbe to extract the model name and view setting from the model using CSharp and the API interface? Ideally I would like the saved name view titles, but I do not think that is possible.
Thank you
Thank you
