SAP2000 Report Output
gh2130
15
Hi Everyone,
My SAP report output shows joint reactions individually calculated for Dead and Live Load. How can I display values calculated for the Load Combos only ?
I have selected the Combos from 'Report Setup' as well as from the Design menu. However, it still shows reactions calculated for individual load cases.
Can someone please help ..
gh
In my version 18, all load cases and combos are selected by default for reporting output tables. If after running your analysis you go to Display menu>Show tables, click the "Select load cases" button. There you can pick and choose which load combos and cases to include in your reports.
The Design menu is not for reporting, it's for specifying which combos you want to include in design code checks.
Thank you "Stressed" for your reply.
I agree that selecting load combos from Design menu is not related to the design report.
My issue is that my analysis and design seems to be OK with desired load combos but it shows individual load case evaluation for joint reactions when i create the report.
What I need is to show in the report joint reactions result for the load combos.
Thanks in advance for your help.
GH
gh, you seem to have read the 2nd paragraph of my post, but skipped over the first paragraph where I explained how to do exactly what you are asking for using the "Select Load cases" option. Please reread
