Save a new version of an assembly 2
EngineerInv
12
I would like to save a version #2 of a an existing assembly and its containing parts. Meaning when I edit parts in version #1, the #2 should not be effected, and vice versa.
(When I use "Save as" only the assembly file is copied and it is linked to the original parts in #1.)
What is the correct way to do this???
I also use DA. If you only want to change a few parts in the new assembly you can use 'Copy and Replace' - this is quicker than DA if you only have small changes.
mcgyvr, wjaroszynski, EngAddict - THANK YOU :)
Design Assistant works.
A bit tricky though that you have to acces it through the explorer by rightclicking the file, and NOT from within Inventor, to get acces to the "Manage"-function)
Can you recommend using the Vault-function? (if so, then why)
Again - thanks!
Vault is a whole different beast.. If you don't use it now.. You don't want to use it just for this. It allows complete document/file/revision management,etc... IT is great for companies with more than 1 designer.
You can read about it here..way to much to type into a post
