save a perspective JPEG
valveman47
Industrial
Apr 1, 2005
4
Hi
I set up a part or assembly on screen as a perspective view.
When I go to the Save a Copy to export it as a high res JPG, the view clicks back to the default iso view.
Any way around this issue?
valveman47
What version are you using? WF2 or 2001. I use 2001 without any probems.
Best Regards,
Heckler
Do you trust your intuition or go with the flow?
Hi Heckler
2001
The intention is to save a hi-res jpeg of a perspective view of the the part.
valveman47
i think there is a pick to "pop current window" don't let it do that.
don't recall anything like that.
Where do I look for that?
Just sorted this one!
The trick is to
Open Save A Copy.. dialogue box first
then
View | Model Setup | Perspective
then save the file at the resolution you want.
Thanks anyway.
