Save .lis file in ANSYS 13.0
QwertyKev
Aerospace
CA
I am fairly new to ANSYS and seem to run up against a roadblock after many hours of searching help files and on-line forums. I seem to be having trouble automating a save operation of a .lis file using the command prompt in ANSYS 13.0. I have reviewed other threads on this issue but none of the solutions seem to work for me. This is my code at this point.
!Print MST and MSB in external Window (element tables)
PRETAB,MST,MSB
/OUTPUT,C:\Users\Name\Desktop\TEST,txt,
Every time I run this code the text file is blank. If someone could point me in the right direction that would be wonderful.
You have to change your output to TEST.txt before you print out your etable results for the output to be stored to file. So, the /OUTPUT command comes first.
//signed//
Christopher K. Hubley
Mechanical Engineer
Sunpower Incorporated
Athens, Ohio
Okay, I switched the lines around but the end result is still the same (blank text file on the desktop).
PRETAB,MST,MSB
Something tells me I need another line of code somewhere else, but I am not sure what or where. Any help with this would be much appreciated.
Yes indeed you may have - your code doesn't show an ETABLE having been defined, although you refer to labels MST and MSB. You need to first define the element table (ETAB) (along with labels) before you can print it using PRETAB.
Something like:
Code:
/POST1
ESEL,S,....   ! select the elements for the ETABLE
ETAB,....     ! define items to be placed in ETABLE
PRETAB,MST,MSB
/OUT
See faq569-1083 for details on how to make best use of Eng-Tips.com
