Saving an Autocad file which is 'Write Protected' 1
luvlyjubblytoo
7
0
0
GB
I have just re-used an old autocad drawing, re-numbered it and hit the sace button.A message has come back saying this drawing is 'write protected'and cannot save. How do I remove this setting.
That's just what I did. The original source file was a different number. I used 'save as' to create a new file but the write protect seems to have carried over!!
There were no permissions issues evident. I have however just resolved my problem. I saved the file as a temporary number,which worked then re-saved it as the file number I required.Whilst solving the problem I guess the 'write protect' issue will remain a mystery
When you saveas, go to the TOOLS tab, then SECURITY OPTION tab. There, you should be able to turn off the save with a password option by deleting the password. Does that work?
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Could be. We are using AutoCad 2005.
Albert Einstein
If you opened the file from a read-only source (network drive or CD) then you won't be able to save it. A SaveAs will not work unless you change the destination drive or folder to one you know is read/write.
