saving drawing without references
AeroNucDef
Aerospace
May 29, 2009
135
Hi all
I seem to have a problem.
How do I create a drawing thats not directly linked/reference to the part that it comes from.
In other words, when I create a drawing, and then modify the part, the drawing updates. How do I stop this. I just need the drawing without modifications.
Thanks grunt58, but it's not working. When I make a change in the part it still updates the drawing.
corblimey,
It works when I save as a DXF, but is their anyway to save it as a slddrw?
Wouldn't you want the drawing to reflect changes to the part? To do otherwise, as you have requested, depends on what and why you want to do this.
You can make a non-slddrw file as CBL has suggested. But if you want a slddrw file linked to a part then by default it will reflect changes to the part.
There are many suggestions that can be offered, but they would be better targeted if we knew the what and why you want to do this. Please explain.
- - -Updraft
Save as detached drawing, then change the model filename.
The drawing will not be able to find the model. SW will prompt you to find it, if it thinks the model needs loaded.
Another thought and Im supprised it has not been suggested is make a configuration with the changes you make suppressed.
Certified SolidWorks Associate
SW2009 X64 SP 1.0
Dell Precision T5400
Nvidia Quadro FX 5600
Xeon 2.5GHz Quad Core, 4GB RAM
XP Pro X64 SP2.0
Save as a different part and drawing.
One of the points of having 3D solid modeling is that the drawing and model is associated, or parametric.
IMO, to break them, might as well use ACAD...or a cheaper CAD.
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
If it does not say Detached Drawing under Files of Type box on any subsequent saves it will become a regular solidworks drawing and become attached again. Detached Drawing and Drawing both have the same file extension .slddrw . If you save as a detached drawing then close the part the drawing should remain detached.
Michael
