Letsby_Avenue
Industrial
- Aug 22, 2022
- 3
I am researching on behalf of a scientific team that has built a small scale vessel to heat a specimen inside a chamber (300C) under high pressure (3500 psi). It is a basic extreme pressure cooker. We want to scale-up the chamber to higher proportions so that the samples created can be greater in size. We believe that a custom high temperature high pressure vessel that can have a large enough door/entry point to insert the samples, would work.
We would ideally like three pressure vessels that could hold a chamber containing the specimens. The chamber which holds the specimens (not vessel) would be pill shaped, with the larger number being the circumference of the pill, and the smaller the depth needed. Sizes we would like would be:
1ft x 0.5 ft
4ft x 2ft
10ft x 5ft
Our smallest two vessels would ideally be able to fit more than one pill chamber of the above dimensions. The samples will contain a mixture of water and powdered bentonite clay, so we need a vessel that can hold this weight. I am not sure if frames can be built inside vessels to hold the chamber containing the samples - I am happy to go with your suggestions.
From our findings that created the ideal sample, the pressure vessel would need to be able to run continuously for 24 hours or more per cycle to get the results we need. The clay pill we are heating up has to be at 300C, so we might need the autoclave to heat above this for this to be achievable.
We are looking for a pressure vessel that is economical and quiet/silent to run. I have attached our small scale circuit.
Do you think an autoclave or high pressure vessel heated with heater bands (replicating our model) would be most economical? Are there any other options you can think of to streamline the process?
Thanks so much!
1ft x 0.5 ft
4ft x 2ft
10ft x 5ft
Thanks so much!
