Scaling in one direction only
victroladoctor
10
Is it possible to scale one in the x direction and not in the y direction?
victroladoctor,
what do you want to scale?
You can convert objects into blocks.
blocks can be scaled with two different values.
Lothar
ADT 2004
This works fairly well; essentially it creates a block, inserts it with a user defined scale factor, explodes the block and then purges. It explodes plines though. Thanks to an unknown author.
Code:
;;;SCALEAXIS.LSP
; ERROR TRAPPING
(defun errtrap (msg)
  (cond
    ((not msg))
      (member msg '("Function cancelled" "quit / exit abort"))
      (command "undo" "")
      (princ (strcat "\nError: " msg))
      (command "undo" "")
  );cond
);defun
;  MAIN ROUTINE
(defun c:scaleaxis (/ *error* *ss1 bspt ax mult refpt refdx newdx)
(command "._undo" "end" "._undo" "begin")
(setq *error* errtrap)
(setq ss1 (ssget))
(setq bspt (getpoint "\nSelect basepoint: "))
(initget "X Y Z")
(if
  (not
    (setq ax (getkword "\nSpecify axis to scale: <X> "))
  );not
  (setq ax "X")
);if
(if
  (not
    (setq mult (getreal "\nEnter scale factor or <Reference>: "))
  );not
  (progn
    (setq refpt1 (getpoint "\nSpecify reference length: "))
    (setq refdx (getdist refpt1 "\nSpecify second point: "))
    (setq newdx (getdist refpt1 "\nSpecify new length: "))
    (setq mult (/ newdx refdx))
  );progn
);if
(setvar "expert" 2)
(setvar "explmode" 1)
(command "._-block" "SCALETEMP" bspt ss1 "")
(command "._-insert" "SCALETEMP" ax mult bspt "0")
(command "._explode" "last" "")
(command "._-purge" "blocks" "SCALETEMP" "n")
(setvar "expert" 1)
(command "._undo" "end")
(princ)
(*error* nil)
____________________
Acad2006, Terramodel
The whole drawing was converted from a pdf and somehow the scaling was off. I tried to make the whole drawing a block but ACAD was asking for a parameter and it would not accept any answers I gave it. If you could explain how to scale a block in one direction, I would appreciate it.
The scaleaxis is a bit (depending on the scale) or a lot over my head> But nothing beats a failure but a try.
Thanks to both of you. Happy thanksgiving
The scaling of a block can only be done after the drawing was made into a block. Assuming that you have made a block, go to the insert pull down menu and select block, the insert block on the screen will ask for scale in the x,y,directions-just fill in the value, then OK and the block drawing with its new scale value will appear.
