Schedule
TECHDOC
11
HI Guys...
Can any body tell me the schedule for this pipe..:
SEAMLESS BE SCH STD B36.10 ASTM A 106 GR.B....Also tell where to look for its frictional loss data.....
help me ASAP
The schedule depends on the OD for Sched STD.
David Simpson, PE
MuleShoe Engineering
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
A common suggestion for pressure losses here is Crane's flow of fluids. There's likely some general information on the web for more common fluids.
If it's under 10" then it's SCH 40. A106 is carbon steel so absRoughness = ~0.00015 ft
