Sam165
- Sep 28, 2020
- 12
Hi fellow structural engineers. I was recently out on an investigation of a one-story wood frame structure located in Oklahoma built in the 1970’s. The ceiling gypsum board was showing major straight-line cracks across the seams of the panels and diagonal cracking at air conditioning penetrations.
The roof is framed with scissor trusses that span approximately 45-feet. I climbed into the attic and noted that the vertical members directly under the peak of the truss are completely separated from the metal plate. This happened on the majority of the trusses above this structure. One truss also had a weird looking vertical that seemed to be spliced. The supporting exterior walls were not visibly displaced laterally. No cracking in the exterior brick veneer to indicate differential movement.
I’m trying to figure out what caused this failure to occur. Was it bad manufacturing practices when these plates were installed in the 70’s? Moisture/temperature variations in the wood causing the metal plate teeth to pull out? One truss vertical being modified at an unknown time that failed causing a “domino” effect to the adjacent trusses?
Weather data does not seem to indicate any high-wind events occurring at this location recently, and no wind damage to shingles or other components of structure/property was observed.
Sam
Sam
