What code applies to the piping/ducting that is connected from a tank nozzle to an emergency vent/conservation vent? For this example, a tank built to API-610 is located indoors, and the piping/ducting essentially routes up throught the roof to the emergency and conservation vents. B31.3 appears to exculde this piping in 300.1.3. It seems that given the low pressures, thin wall stainless tubing or piping with plate flanges (say 1/4 or 3/8) will work fine. And due to the low pressures, the rules for unlisted components (B31.3) seems excessive. Also, SMACNA does not seem appropriate from what I have seen, as leaks in some of the ductwork are allowed. The client wants to save money and use thin wall stainless and plate flanges, but I'm just not sure what code applies. Any help is appreciated.
