azmirosman
- Jan 11, 2019
- 20
Dear All,
I would like to get assistant on the dented at external pressure vessel head.
During level 2 of structure installation (in Module), the existing pipe support is resting on the top head of the pressure vessel.
Existing pipe support is prewelded at another structure at level 2 and accidentally i believed there was force from the support to the vessel head.
And after remove the pipe support, we performed inspection at clashing area and found that there is some scratch that preliminary measurement of depth is about 0.8 mm to 1.2mm.
We will call AI and vessel fabricator to inspect and provide judgment and solution.
However, before we come to discussion, i would like to know any reference or standard that i can refer regarding requirement of maximum depth of external wall.
From my understanding, i only can find tolerance of roundness in UG-81.But nor able to find any clause that refer to dent and depth for external wall.
Appreciate if anybody can assist.
I attach here picture before and after remove the clash pipe support.
