Screw Loosen Analysis 2
Lee.Conti
Automotive
Nov 8, 2019
87
Hi I wonder if anyone has done any analysis to check if the screw get loosen due to thermal effect?
Designer feedback the screw may get loosen due to thermal cycle... and I wonder if the screw is being screwed into the part and locked, how could it get loosen?
Tm...
Based on the first and second links I'm OLD.
NOTE: can't get Your last link to work... 'illegal character' warning... I need to know how old I really am.
Do the number of typos in posts-over-time also count?
Regards, Wil Taylor
o Trust - But Verify!
Hi WKTaylor,
It is a system level product and the screw is normal 3x16 type.
How do you account for the thermal cycle effect or just running the analysis at high and low temperatures?
Doh, TM... I would hazard a SWAG that the cap-screw [in the posted image] has high quality coarse threads.
Regards, Wil Taylor
WKTaylor,
I would think .001-.004" clearance would be perfectly acceptable. Should the bolt to hole clearance be eliminated? A core drill being is used for match drilling after the wing assembly is fit up?
M... ???? OK... I am lost in translation...
Q/I I would think .001-.004" clearance would be perfectly acceptable. … based on what reasoning??
A. What kind of joint are YOU referring to?
Q/I Should the bolt to hole clearance be eliminated? Huhhh?
A. Swaged-collar Lockbolts, Hi-Lok pins, etc... can be installed in transition fit or light interference. Conventional bolts should only be installed in clearance fit holes... or with extreme care/process controls... light interference-fit by 'freeze/shrink-fit' techniques.
Q/I A core drill being is used for match drilling after the wing assembly is fit up?… OK, OK, OK... You are not opening-up generalized issues...
I sense You may be referring BACK to my prior discussion/example [4 & 6 August postings]… IE: experience with loosening bolts/nuts discovered on my 1960's-1970s' era light attack jet during a routine condition inspection...?
Please advise if I just figured-out where You were actually 'going' with Your [3] statement-questions...
Regards, Wil Taylor
