Script to remove part of a text block?
Kalayna
Industrial
My company is doing a lot of updating right now, and there is some information on all of our (50,000+) prints that needs to be removed. While I can do some really nifty things w/our other cad program, I'm pretty clueless when it comes to doing the more detailed stuff w/AutoCAD. I've linked 2 examples below- is there a way to script removing the last 2 items (routing and send to) in the blocks on the bottom left corner? We have prints set up both of the ways shown.
Yes, with some custom programming.
In one drawing, the "SHIP TO: WELDING" is a attribute value in a block insert; in the other drawing "SEND TO: SHIPPING" is the last line in some MTEXT. A (lisp or VBA) routine would search for the mtext & delete the offending text, and search for the block insert "routing" and clear the attribute value. Now include this routine in a batch program such as Scriptpro to run on all the drawings.
Thank you for the reply- I knew it *should* be relatively simple, but since I don't work with AutoCAD in depth, I wasn't sure where to start. Time to get started on implementation!
