Script to see what users have ST1 license?
scotty053
Aerospace
Apr 28, 2017
3
For some reason some versions of our Catia (R24, R25) won't show what users have our floating ST1 license checked out.
Does anyone have a script that will display what users have a certain license checked out?
Any help would be appreciated.
check the DSLS pdf doc, it should provide enough info to make a script.
CATIA should inform you if you try to grab a license that is unavailable and should list all users with that license.
Eric N.
Yea, some of our versions of Catia will show what users have it and some don't, not sure why.
I am trying to learn how to write scripts, but it is a little intimidating. Do you have any starters or tips? Thanks.
did you check the DSLS help file?
Eric N.
Yea, and it shows how to do it while logged into the license server. I can make a batch file that will output a .txt file with the user info in it. What I am struggling to figure out now is how to do this from my local machine.
install DSLS on your computer
Eric N.
i4blt.exe -s -n "code2" > c:\temp\cat.fil
Vendor Name: CATIADBS
Product Name: ST1
Product Version: R1
License Type: Concurrent Access License(s)
---------------------------- Usage Information ---------------------------
Concurrent Offline Soft-Stop Queued
Licenses In-Use In-Use In-Use Not In-Use Requests
1 0.00 0.00 0.00 1.00 0
=== End of Product Status Report ===
