well, acutally, you can't do that with abaqus cae. you have to code that by yourself in fortran code.
SUBROUTINE SDVINI(STATEV,COORDS,NSTATV,NCRDS,NOEL,NPT,
1 LAYER,KSPT)
C
INCLUDE 'ABA_PARAM.INC'
C
DIMENSION STATEV(NSTATV),COORDS(NCRDS)
user coding to define STATEV(NSTATV)
RETURN
END
but the SDVINI is just used to initialize the solution dependent state variables which are then available for the own coded user subroutines. so, this has nothing to do with abaqus cae ...
Thanks for the tip, but doesn't work, I don't know why. When I checked all the statev's was initialized with zero.
If you have any suggestion I apreciate.
