For those who have not yet seen or heard...
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
In a traditional parametric modeler, you can edit a feature by specifying new values for it's parameters. For example, for an extrusion feature, you can modify the extrusion distance and the feature will be updated. You cannot do this with a feature in Solid Edge ST. This is because the features here are dumb and have no parameters to edit. The only way to change the extrustion distance is to pull/push the face you extruded in the first place or set up a dimension and edit the dimension. The features in Solid Edge ST are merely a collection of related faces that make up the feature. They do not even know which sketch was used to create them. You can go ahead and delete all the sketches in a part and the model will hold up just fine.
