Nov 28, 2009 #1 kthant Mechanical Jun 28, 2007 44 0 0 CA Hi all In SE ST1 i don't have control over variable after i create a part from sketch? i see that in variable table user dimension disappear after i create a part from sketch . is any other way to have control over variable ? All the best
Nov 30, 2009 #2 PatCouture Mechanical Jun 6, 2003 534 0 0 CA Are you working in Synchronous mode or Traditionnal mode? Upvote 0 Downvote
Nov 30, 2009 Thread starter #3 kthant Mechanical Jun 28, 2007 44 0 0 CA hi Pat Synchronius mode of course in tradition mode i see all variables. Upvote 0 Downvote
Nov 30, 2009 #4 PatCouture Mechanical Jun 6, 2003 534 0 0 CA You probably already checked that but do you have a filter on in the variable table? Upvote 0 Downvote
Nov 30, 2009 Thread starter #5 kthant Mechanical Jun 28, 2007 44 0 0 CA hi i think so. my question was why i can not change parts changing values in variable table. dimensions in variable table are inactive ( grey ) i can not change them. i attached a picture maybe will be more expressive. thank you http://files.engineering.com/getfile.aspx?folder=11ca92a4-cadc-46d9-9854-1e2ec88bd3c1&file=variable_table.JPG Upvote 0 Downvote
Nov 30, 2009 #6 PatCouture Mechanical Jun 6, 2003 534 0 0 CA It's an improvement they made in ST2 in ST1 you can't change the variable unless they are locked and they don't interfere with live rules. In ST2 you have an option available if it's possible to change the value. I'm sorry not to be of any more help. Patrick Upvote 0 Downvote
Nov 30, 2009 Thread starter #7 kthant Mechanical Jun 28, 2007 44 0 0 CA thank you Pat i think is time to install se st2 all the best Upvote 0 Downvote
