mikeyd2
- Feb 3, 2011
- 7
Hello All,
I am working in a Pulp Mill and have been given the task of troubleshooting a pump in which mechanical seal failure is causing water contamination and failure of the front bearing. We are having to replace the bearing approximately every 6 months. The front feet of the pump is mounted to channel which is welded to the base. The welds have continously broken over time and have been rewelded. The channel has also cracked and been re-welded.
The pump is running on a fairly high efficiency part of its curve based on flow data taken from the DCS, so run out or low flow condition is not the problem. The fluid is pulp stock and I am not certain of the temperature (probably around 50C). The ambient temperature is ~8C (winter) and ~23C (Summer).
Some think that the problem is from entrained air due to the agitator that is installed on the same tank 5 feet away from the pump suction connection. This is a concrete, tile lined tank. I have been informed by the pump manufacturer that placing the agitator close to the pump suction is a common practice and diverts the flow around the circumference of the tank and into the suction.
There is excessive vibration when this pump is operating. I do not think cavitation is the culprit as there is no pitting or corrosion on the impeller or casing when it is re-built.
The pump suction is horizontal and is a straight run of 24" diameter SS pipe (~4 ft long) from the tank followed by a 24x14 exccentric reducer into the pump suction. Could thermal expansion in the suction be causing this problem? It seems like a short run but the tank it is connected to will not flex like a thinner walled metal tank.
Another reason why I think piping loads may be to blame is the arrangement of the discharge piping. The pump discharges vertically up about 9 ft before turning horizontally. Directly after it turns horizontal there is a guided support which only allows axial growth. This support looks like it is restraining the piping from growing up from the pump and putting the thermal expansion loads back into the pump.
Does it sound reasonable that piping loads may be causing this problem? Does anyone have any other ideas at what may be causing this?
Thanks.
Thanks.
