AnCheng
- May 26, 2023
- 10
Hey there,
I'm a maintenance engineer at a utilities plant. And I need to evaluate the sealant we'll use between the casing halves of the turbine. The turbine inlet steam reaches tempretures between 300-400 celsius. However, the sealant we've always used has a flash point of 150. Would this be a sufficient enough sealant? Is the flash point not relevant? Any other considerations I should take in choosing a sealant for the tubrbine casing?
Any help would be greatly appreciated.
