Dear All,
we need to seal two test caps against the buttweld ends of a 12" class 300 cryogenic valve and cannot use our usual Spiral Wound Gaskets: the slot for the gasket is 5.5 mm deep, 8.0 mm wide and inclined respect to the flange flat-face plane of about 40°; the relevant mean diameter is about 315 mm.
Now we are using a 8.5 mm square cross-section graphite braid as a seal, but it leaks at ambient temperature and relatively low pressures. It should be tight up to 30 bar of internal helium pressure and down to -196°C temperature.
What kind of sealing material and cross section would you suggest?
Some websites give Virgin PTFE, for example, as appropriate for low temperatures down to -160°C, others give it as appropriate for cryogenic temperatures down to -196°C or -268°C... what do you think about it? And what about fiber reinforced or filled PTFE?
Thanks to all, 'NGL
Thanks to all, 'NGL
