jetpackjbd
Hi, not sure where this belongs or if I’m even on the right website for this, but I’m looking for a very small compressor/pump for a project.
Specifications:
[ul]
[li]24V and under 5A ideally[/li]
[li]Slightly noisy[/li]
[li]Cheap, under $50[/li]
[li]Small[/li]
[li]Flow rate and PSI aren’t important[/li]
[/ul]
What I’m trying to do is replicate the sound of an engine on an electric scooter and design exhausts for it using a compressor instead of an engine.
I had thought about using a tire inflator, however cheap ones are often deafeningly loud and draw 10+ amps. Something like a blood pressure monitor pump would be ideal, though I can’t find any that could handle over 12V. I’ve tried 3D printing one before, but extruded plastic alone isn’t smooth enough.
Any suggestions are appreciated!
Specifications:
[ul]
[li]Small[/li]
[/ul]
