Seawater Piping Materials Evaluation 3
ATSMech
7
I am working on a materials evaluation and life cycle cost analysis for a project. I have read a fair amount of the threads on the subject, and I have done enough research to thoroughly think myself in circles. I would like to get some opinions regarding my current options.
Conditions:
Dry Dock Dewatering / Drainage Systems - potential for long periods of stagnation (ex. dewatering system runs roughly once a year depending on ship maintenance timeline)
Located on a historically polluted river (lots of shipyard & industrial work).
Water Quality: no tests on file, but extrapolating from average salinity maps I am looking at a chloride concentration of roughly 12,000 ppm.
Water temp: max summer surface temp is 86F(30C).
Max flow through the system will be around 12 fps.
Life Span: 50 years (span of the LCCA not necessarily of the systems)
Pipe sizes: 6", 8", 14", 20", 24", 54"
Materials Considered:
Cement Lined Ductile Iron (w/ or w/o cathodic protection (CP))
316L SS (w/ or w/o CP)
2205 Duplex
2507 or Zeron100 SDSS
Questions:
1.) Has anyone crunched the numbers between materials like these to get a gut feel for the best choice? I am currently leaning towards Duplex or Super Duplex for the 24" and under and going concrete lined DI for the 54".
2.) I have read about PREN values and the issues with crevice / pitting corrosion, but is there anyway to extrapolate that resistance to an expected service life? I am a design engineer now but was an API certified inspector in my last career, and I know that just because you have initiated corrosion doesn't mean that the material is at the end of life. It seams like most articles talk purely about resistance to the initiation of corrosion.
3.) In general, is going down the road of cathodic protection worth it compared to alloy selection? In other words, is it worth while for me consider given the conditions of the project? I am leary of complicating the system and adding required maintenance tasks that may or may not get performed.
Materials like HPDE and GRP are in the back of my mind as well, but I am not as familiar with the joining and installation methods.
Thank you in advance.
Just got some revised operational info.
The 54" de-watering system will have a chance to drain, and the drainage & sump systems should operate every other day. As we work to renovate the DD (i.e. reduce the leaks), that downtime may increase, but I don't see the stagnant periods being longer than a week.
-Aaron
