Under "Vessel (Production) Impact Tests Plates" (UG-84 (i) of Section VIII Div 1), there is the following statement about the materials used to make the test plate:
"The vessel impact test plate shall be from one of the heats of steel used for the vessel..."
What's a valid interpretation of this? That if the vessel is made from SA-105 and SA-516 Gr 70, the production test plate could be made from just the same heat of SA-105?
