Hello Sir,
We are about to start alkali boil out of our water tube boiler (20 kg/cm2G and 70t/h).
I will be highly grateful if you can comment on my few doubts:
1. Can we use Demineralised water to
prepare chemical solution out side steam drum?
2. We have to first give a flush to the
steam drum before sending chemical into it, what precautions
should i take while filling steam drum by hot Boiler feed
water (105 C and 22 barG)?
3. Actually we want to do pre dry-out
of waste heat boiler refractory along with boil out
opearation. Boiler vendor says that heat steam drum upto
boil out pressure ( he does not mention pressure value in
IOM) and then cool it. repeat this uoto 8 hrs then drain all
chemial solution to complete the boil out. However
refractory vendor says heat the steam drum untill producing
steam of 2-4'barG and temp of 150 C and hold it upto 20 hrs
then cool it to achieve pre dryout along with boil out. Do
you think any problem with this?
4. Any valuable suggetsions on
preserving boiler after boil out, actually right after boil
out inspection, we will be doing complete dry out of
combustion chamber refractory by heating up to 1200 C ?
Thanking you.
sajid
Thanking you.
sajid
