Seeking an adhesive with unique properties
brianjames
Automotive
Nov 2, 2020
1
Working in the automotive field and need an extremely strong adhesive that will setup/cure in seconds but also can be quickly removed with a solvent et al.
Currently using a form of concentrated hot glue stick but seeking something much stronger- imagine cyanoacrylate but something that removes a bit easier
TIA
Brian
It sounds like cyanoacrylate is what you want. Removal from metal can be done with acetone or methylene chloride. Removal from other materials might require an evaluation of chemical resistance.
It will certainly help to know what materials you are sticking together with this adhesive.
