I want to detect a 2 Amp Primary SEF on an isolated 3 phase underground circuit. My primary current will be around 700-800 amps maximum when starting a series of water pumps. There is a requirement that the SEF at the 11kV outgoing feeder towards the Pump Station should be limited to 2 Amps. I can not detect that with a the specified OC/EF relay whose setting range is 0.05 to 2*Io with a 1000/5 A CT. This relay has a seperate input for a Balanced Core CT.
Could anyone advise me on how to accomplish this task? I am used to 20% and above EF settings. I saw something about Interposing Balanced Core CT's which I think may be useful.
