StarDeltaPower
Industrial
I have a 1500kVA 11/0.415kV transformer, which has LV earth protection and upstream 11kV protection. The grading is at about 0.25s between the 2 curves under a fault on the LV side of the transformer.
I have been asked to add an SEF relay to the LV side protection. Normally I would grade this to trip a 2s more or less after the primary LV earthing protection. In this instance though, as the 11kV curve can not be altered and made to trip slower, should the SEF curve sit between the LV and 11kV curves? Or react slower than both the LV and 11kV protection as it's purpose is backup?
