LOTE
- Sep 9, 2018
- 149
I am designing a segmental block retaining wall that forms the walls of a dry detention pond. My scope is just the retaining wall design. One side of the pond will act more like a "dam" with the backside of the wall sloping down. See attached cross section sketch (assume this is not to scale...). The wall is roughly 5-ft tall.
I plan to have the typically 12" of clean gravel behind the blocks and to design the wall for rapid drawdown. What type of fill would you spec out for the rest of the reinforced zone and the retained zone along the slope? Should this be an impermeable material to prevent seepage?
How would you design for the negative slope?
The owner has not hired a geotechnical engineer yet, but it will be a requirement for me to design the wall. What things should I notify the owner to ensure is in the geotech's scope, and what questions should I pose to the geotech?
