Zoletres
- Jun 30, 2024
- 2
I wasn't sure if this should be in the civil or structural general discussion, but I figured I'd ask here because of the design criteria is usually in the structural part of plans.
I work in a project management position where as part of the submittal packages I have to provide seismic anchorage calculations, I'm in CA. There are a few PEs my company has used, both civil and structural. Each have a different ways of preparing, presenting, etc. their reports.
One big difference I've seen is deciding to use 1 bolt vs all the bolts required when they do the calculations use the Hilti or Simpson softwares.
How does one decide when make this decision for the calculations? Or other choices?
I mostly deal with non-structural equipment in my position (pumps, compressors, tanks) if that helps answer anything.
