Blackfairy
Hi, I have an electrical panel that is attached to the ground and is just elevated by some HSS so the weight of the panel is greater than the HSS. According to ASCE 7-22 13.2.9, if the effective seismic weight of the nonstructural component (panel) is more than 20% of the combined nonstructural and the supporting structure (HSS), then it should be design as per Chapter 12 (building Structures) and if not then Chapter 13 applies (nonstructural).
I just want to verify what forces to use to design the anchorage of this to the ground. Is it Chapter 12 which is the typical Cs x W formula or Chapter 13 using the Fp formula?
