strguy11
- Nov 29, 2005
- 232
I have a 2 story building with a flexible roof diaphragm. (Metal deck untopped with concrete shearwalls). In one area between the the shearwalls there is a gym area, where basically there is no floor. The demising shearwall between the 2 areas will protude thru the roof, breaking the roof into 2 sections.
When applying the EQ loads vertically to each of the floors, I noticed that for the area where the gym is, the weight for that portion of the roof is greater due to the added wall trib height, than the other roof areas.
Should I treat these areas as 2 separate roof diaphragms and apply the forces individually, OR, do I just combine the weights into one mass for the roof, and design the diaphragm for the resulting load. I cant find any examples that address this, however, the one example I did find talks about an idealized mass theory which seems to suggest the latter option is correct, however, If I use the other method I get a slightly higher diaphragm design load.
I am going to use the worse case, but was wondering what others are doing.
