MAB70
- Aug 19, 2019
- 25
Hi all,
I have three question with regards the lateral resisting systems in the ASCE7;
1. When you use dual system of moment frames, it says to be capable of resisting 25% does that mean it doesn't necessarily need to have enough stiffness to attract 25% of the load and only as long as its designed for 25% ? or shall i increase the stiffness of these frames so naturally attracts 25% of the load?
2. When you use building frame system using the shear wall option, in any building naturally the shear wall cannot represent 100% of the lateral stiffness of the building so what is the minimum acceptable percentage of lateral force that it needs to attract.
3. Point 2 leads to this one as what will be the difference between building frame system (shear wall) VS Shear wall frame interactive system, since you will have to have other components in the building taking load anyway.
