JAE
- Jun 27, 2000
- 15,543
I have a large building - 3 floors each with about 300,000 sf. Between the second floor and the roof there is a small (8000 sf) mezzanine attached to the columns.
Under IBC 2000, how do you determine the lateral seismic force on this small mezzanine? I can get the story forces for each level based upon the overall building - just not sure if the mezzanine counts as a "level" or if its mass gets added to the main floors and the seismic load is calculated separately (to check the columns) as an Architectural component?
