designrider
- Oct 25, 2007
- 50
Question: What is the proper use of Seismic Response Modification Factors:
Option 1:
Response Modification Factor values greater than 1.0 , which are applied to select member effects in recognition of ductility and energy dissipation ability, should only be applied to member moments. R value use for column seismic axial effects is not appropriate as it would be contrary to the design specifications intent.
OR
Option 2:
Response Modification Factor considers inelastic deformation (i.e. ductility) of the system that allows the seismic response to be justifiably reduced. Seismic forces develop from ground shaking while the level of ductility of the system reduces the energy transmitted into the structure which engineers model as a lateral force. Thus, ALL seismic force effects (moment, axial, shear) are reduced because the system itself is dissipating the energy before it can develop as a resulting lateral force.
ASCE7/IBC uses R to reduce the Base Shear. AASHTO LRFD uses the R factor to reduce the “force effects”.
Which interpretation above more accurately defines the loading occurring in a member?
Option 1:
OR
Option 2:
