matanuska11
- May 17, 2011
- 10
I am looking for info on Schweitzer 2431 controllers, specifically for a Siemens JFR voltage regulator. I have three units on a three phase distribution system, being feed from reverse(source side voltage is supplied onto the L bushing, load voltage on the S bushing)with the controller mode set to BiDirectional, intending to see being fed from either S or the L bushing on the regulator. The controllers are all maintaining a Auto-INhibit status in the BI-DIR mode, but in a LockedReverse mode, the units regulate. Mind you, I have (company I work for) another SEL Voltage regulator on another distribution line that functions just fine in this mode. the settings are basically the same, except the unit that functions ok, is newer and it's kVA rating is a little bit larger. I appreciate any info in relation to this, thanks.
