Select output request in input file
fanch35000
9
0
0
FR
Hello everybody,
I currently work on Abaqus/Standard 6.6.3. In order to reduce the .odb file's size, I try to control the field output requests extraction.
I would like to select the following field output requests: PEEQ, PEMAG, MISES, CPRESS, RF, U.
I don't exactly know how to include this in the input file. I tried with the following syntax:
*output, field
*Node output
U,RF
*Element ouput
PE,PEMAG,PEEQ,MISES
*Contact output
CPRESS
The calculus runs without syntax errors, but when I open the odb file, I have an acess to other requests that I haven't selected, like RM3 for exemple, or AC Yield.
I wonder if it is not because I use the line :
*output, field
and then, because there's no precisions about the option, the FE code considers by default variable=PRESELECT.
Does anybody know how I can select my field output in the input file?
Thanks a lot.
Best regards.
Fanch
Hi Gurmeet,
And first, thanks for taking care of my problem.
Indeed, I have Abaqus C.A.E. But, the problem is that the syntax I have exposed in my previous post is already extracted form a CAE model...
I still haven't found how to select output requests. But I go on working on it.
Fanch
