mech_cool
- Nov 2, 2019
- 4
Hi All,
I want to select a pump for high temperature liquid with following data/parameters:
Data & Parameters
Flow Rate – Approx. 10 lpm
Liquid Temperature – 300 C
Pressure loss in circuit – 0.4 bar
Liquid Data
Viscosity – 4 cP
Density – 1.90 g/cm3
The application is in solar cookstove where a liquid will store thermal energy and circulate the liquid into the system. I would appreciate your help if you can suggest a compact and low weight pump for above requirement.
Data & Parameters
Liquid Data
Viscosity – 4 cP
