I would like to select all dimensions (only) in the sketcher in order to toggle lock the dimensions. The only way that I know how to do this is to manually control-click each dimension. If I window select the dimensions, most of the time it will also select some kind of geometry as well. Then, the program will not let me lock the dimensions.
Is there some kind of command, or has someone figured out a macro that will allow you to select all dimensions without selecting geometry in the sketcher?
Thanks!
Thanks!
