Parana Sembiring
- May 19, 2018
- 6
Hi everybody, Please for your advise and comment.
Cheers!!
I have Hydraulic Winch with Capacity 10 Ton SWL, requirement of the power supply (hydraulic pump) is 180 bar, 104 l/min.
The question is, can I use Hydraulic Pump with duty point 400 bar and Flow rate 300 l/min for the power supply?
Please for your comment and advise
My Hydraulic Winch data as below,
Equipped with Control Valve, Pressure Gauge, Gearbox, Pressure Line, Return Line, Drain Coupling.
Hydraulic Winch Motor
1.Type : Hydraulic Motor
2.Size : 200 CC
3. Rated Speed : 580 rpm
4. Nominal Power : 10 Kw
5. Power Supply : 180 bar, 104 liter/minute.
Hydraulic Winch Brake
1.Nominal Static braking : 500 Nm
2. Pressure : 27 bar
thank u
best regards
cheers!!!
Cheers!!
2.Size : 200 CC
thank u
best regards
cheers!!!
