Selecting the items you just pasted via script?
puck
Aerospace
I'm writing a script that lets me select a product or part to copy and paste and then translate them.
The problem I'm running into is getting the items that I just pasted as my selction to translate.
Here is an example of the code and the part that I'm having trouble is where I Set product2 = ?????
<code>
Dim Sel1(0)
Sel1(0) = "Product"
Dim Done As Integer
Dim vbYes As Constants
Dim vbNo As Constants
vbYes = 6
vbNo = 7
Done = vbYes
Do While Done = vbYes
ProdDoc.Activate
Dim SelObject As Object
Set Selection1 = ProdDoc.Selection
Selection1.Clear
vRet = Selection1.SelectElement(Sel1, "Select the Part or Product to Copy.", True)
Set SelObject = Selection1.Item(1)
Set CurProd = SelObject.Value
MsgBox CurProd.Nomenclature
ProdDoc.Selection.Add(CurProd)
Selection1.Copy
ProdDoc.Activate
Selection1.Clear
Selection1.Add Prod
Selection1.Paste
Prod.Update
Selection1.Clear
Dim product2 As Product
Dim move1 As Move
Set move1 = product2.Move
</code>
Any ideas?
TIA,
Puck
Hello there puck.
I guess the latest product/part will be at the bottom of the tree, so you could use a Count property of all your Product's parts or products, and the last pasted part/product would be the one you want.
Haven't tried this myself though...
-bjod
Yeah I've tried that method allready but itdoesn't seem to work in this case.
I tried
<code>
Set product2 = Prods.Count
</code>
Prods was set prior in the script As Products of the top level product.
Thanks for the try though,
Puck
Doh,
Went back and looked at that again and it does work just had to set the item number first.
t = Prods.Count
Setproduct2 = Prods.Item(t)
Thanks again,
Still hitting myself over the head.
LOL,
Puck
