Selection.Search macro
dddn
35
Hi all, does anyone know how to use the TopologyCGMFace command inside a for loop?
the code is as follows
Sub CATMain()
Dim partDocument1 As Document
Set partDocument1 = CATIA.ActiveDocument
Set part1 = partDocument1.Part
Set selection1= partDocument1.Selection
Set hybridShapeFactory1 = part1.HybridShapeFactory
Dim ElementsArray(0)
ElementsArray(0) = "AnyObject"
Status = selection1.SelectElement3(ElementsArray, "name", True, CATMultiSelTriggWhenUserValidatesSelection, False)
For n = 1 To selection1.Count
Set selectedProd1 = selection1.Item(n).Value
selectProd1.Search("Topology.CGMFace,sel") '''''This is the error line
Next
I usually save my selection findings into an array. (Selection belongs to the document, not product)
You will be searching each of the array items for something else (i.e your selection will loose the selected items, and show the new result)
I usually try the CATIA selection first (Ctrl + F); with " add to favorites.." command you can easily copy the search string.
In the code I usually assign a search string that copied text:
Code:
SelString = "Topology.Face;sel"
Dim mySel
Set mySel = CATIA.ActiveDocument.Selection
mySel.Search (selString)
After you've created the array of your selected objects;
in your for loop, clear the selection1, add n:th object of the array to the selection, perform search on that...
regards,
LWolf
Thank you for your answer.
But I can't get what I want:
in the "selectelement3" line I have already created an array, and when I use the "msgbox selectedProd1.Name" it returns the correct names, but it gives me an error in the selection1.search
Where is the error?
I try to modify in this way, but the error is present
Sub CATMain()
Set PartDocument1 = CATIA.ActiveDocument
Set selection = PartDocument1.Selection
Dim SewFilt(0)
SewFilt(0) = "AnyObject"
Dim ret
selection.Clear
ret = selection.SelectElement3(SewFilt, "Select Sew", False,2, False) ''in this selection, i select all the sew surface
numSew= selection.Count2
ReDim oSewArray(numSew)
For i=1 To numSew
Set oSewArray(i) = selection.Item2(i).Value
msgBox oSewArray(i).Name
Next
Call selection.Clear
For i=1 To numSew
Dim selection1 As Face
set selection1= oSewArray(i)
selection1.Search "Topology.Face; sel" ''ERROR'' ''in this line i want search the face that are present in a specifical sew surface
msbox selection1.Count2
Next
End Sub
Help please
Hi ,
I think that the Search method is searching in the document and not inside your array.
Marc
