Sending an Array into an Excel VBA function and Also Getting an Array Out 1
JoelTXCive
933
I am having problems sending an array into an excel function. I also may be having problems getting an array back out.
I'm trying to call a function named "Stem_Wind" and am passing several variables to this function. One of the variables is a 7x4 variant array.
After the function runs some calculations, the output of the function should be a 1x2 numeric array.
I think I have issues passing variables in to the function, but I probably have issues getting them back out too :(...
Attached is the code... I can send more in text format if it helps.
Thank you in advance.
Here is the function CALL
Code:
'Lets redim the array to add 2 more columns for wind shear and moments
    ReDim Preserve StemArray(counter, 6)
    'Set up Some Variables to use in the loop
    Dim POI_Stem(2) As Double
    Dim PointX As Double
    'Loop through all my wall points and calculate shear and moments due to wind load
    For i = LBound(StemArray, 1) To UBound(StemArray, 1)
        PointX = StemArray(i, 4)
        POI_Stem = Stem_Wind(PointX, POI_Special, h_topfence, h_parapet, pressure_wind)
        StemArray(i, 5) = POI_Stem(1)
        StemArray(i, 6) = POI_Stem(2)
    Next i
And Here is the Actual Function:
Code:
Function Stem_Wind(PointX As Double, POI_Special() As Variant, h_topfence As Double, _
h_parapet As Double, pressure_wind As Double) As Double()
    ' This function will calculate shear and moments due to a uniform wind load
    '       Written by JoelTxCIVE
    '       Last Modified 07/10/2018
    'INPUT:
    'For each value sent into the function, we need to determine which region of the wall
    'we are in and then apply the proper equation to determine shear and moments.
    'PointX        -    This is the point I am interested in.
    'POI_Special() -    This is a (7x4) variant matrix with string and numeric columns
    'h_topfence    -    Height of top of fence above wall
    'h_parapet     -    Height of parapet region
    'pressure_wind -    Uniform wind pressure
    'OUTPUT:
    'A (1x2) array containing two numeric values.  Value 1 will be shear and Value 2 is moment.
        'We are going to use a select case operation to compare the PointX value
        'to the special points of interest array.
        Select Case PointX
            Case Is < POI_Special(3, 4)         'in the top fence
                Stem_Wind(1) = 0 'shear
                Stem_Wind(2) = 0 'moment
            Case Is = POI_Special(3, 4)         'at top of wall
                Stem_Wind(1) = h_topfence * pressure_wind        'shear
                Stem_Wind(2) = Stem_Wind(1) * h_topfence / 2     'moment
            Case Is < POI_Special(4, 4)         'between top of wall and nat grade
            Stem_Wind(1) = (h_topfence + PointX - POI_Special(3, 4)) * pressure_wind 'shear
            Stem_Wind(2) = Stem_Wind(1) * PointX / 2                                 'moment
            Case Is <= POI_Special(7, 4)        'below nat grade
            Stem_Wind(1) = (h_topfence + h_parapet) * pressure_wind               'shear
            Stem_Wind(2) = Stem_Wind(1) * (PointX - (h_topfence + h_parapet) / 2) 'moment
            Case Else
                Stem_Wind(1) = 0 'nothing
                Stem_Wind(2) = 0 'nothing
        End Select
End Function
 https://files.engineering.com/getfile.aspx?folder=985a0e26-8c01-4f3b-ab2e-88b36f6f9f00&file=Stem_Wind_Function.pdf
Where does POI_Special come from? Are you sure it is a variant array, rather than a variant/range?
But I think your problem (at least one of them) is declaring the function as a Double array. Try changing:
) as Double()
to:
) as Variant
or just don't declare it, as Variant is the default.
Doug Jenkins
Interactive Design Services
Thank you for the input. I deleted the function declaration.
I get a compile error at this line.......
[highlight #FCE94F]POI_Stem[/highlight] = Stem_Wind(PointX, POI_Special, h_topfence, h_parapet, pressure_wind)
It says 'you can't assign a value to array'
'POI Special' is definitely an array. It contains special points of interest on a retaining wall where equations will change. (such as top of wall, natural grade height, top of footing)
OK, I should have noticed the POI_Stem declaration.
The message 'you can't assign a value to array' is pretty misleading. You can assign a function return value to an array, but you have to declare it as a variant object, without specifying what type of variant it is; so leave off the ().
Instead of:
use:
Dim POI_Stem as Variant
You then need to declare an array inside the function (say Dim POI_StemF(2) as Double), and the final lines of the function will be:
Stem_Wind = POI_StemF
Exit Function
Alternatively, you could pass POI_Stem as a function argument, and add the required values directly to POI_Stem, rather than Stem_Wind. The function return value could then be an error index (or even nothing).
Doug Jenkins
Thanks IDS!
I will give it a shot this evening after work and report back!
IDS.....you are genius!! It worked!!
Thank you!
