Hossein2020
Student
Hi users,
I modeled the vertical cycling of pipe in CEL, which cycles between lower and upper displacement limits.
Now, the upper limit of cycles would be fixed at the specific displacement, but the lower limit would be defined by a load limit.
As I searched in the ABAQUS forum, I think I can do this by using a VUAMP subroutine. set the sensor for RF2 and then try to define a limit on it in the VUAMP.
Having said that, I found a sample VUAMP subroutine uploaded here and then try to use it in a simple way. But, I got the following error:
***ERROR: Sensor FORCE-SENSOR cannot be found but is accessed in VUAMP.Please
make sure that this sensor is defined for this step.
both "inp" and subroutine files are attached here, I would really appreciate it if help me in this case,
Thank a lot
Hossein
Thank a lot
Hossein
