1
- #1
SwinnyGG
- Jan 22, 2016
- 2,580
This is more of a code-related question than a technical one, but I am posting it here because I believe this forum gets a lot more traffic than the code forum does and I don't want to double post. If anyone feels this post is misplaced, I can delete and re-post elsewhere.
Well gents, the mechanical engineer's worst nightmare has been thrust upon me. This post is long, and for that I apologize, but I'm at my wit's end and I'm hoping someone here can help point me in the right direction.
Background: I am a mechanical engineer for an industrial automation manufacturer. I very frequently am tasked with the design of everything from small brackets up to multi-ton weldments to support equipment of all kinds.
When I design a large weldment to hold a piece of equipment, I also need to design that weldment's attachment to the structure in which it will reside. My policy (previously fully supported by the company) has ALWAYS been that any attachment of equipment which is safety critical (much our equipment is large and has overturning moments large enough that if free standing, overturning the equipment is a legitimate possibility) requires SEOR review and approval (usually via PE stamped approval letter, sometimes with new analysis and drawings when required) for release.
The workflow is usually that the weldment or whatever is designed by me, but the structural attachments are not- I provide a drawing of the weldment which indicates equipment loads and moments, and the SEOR goes to work. If we are mounting to concrete, I will use PROFIS to sanity check that I've provided enough anchor points, but I do not provide this report to the SEOR for review (to avoid any question of whether or not the calculations are theirs or mine, I let them duplicate that work. They know it better than me anyways.). For structural steel attachment I will do a similar back-of-the-napkin sanity check, which I do not provide.
I recently have been 'gifted' the 'opportunity' to work under a new supervisor and a new program manager- neither of which have any experience in dealing with projects like the one we are currently working through, which involves a weldment-supported piece of equipment with a large overturning moment.
I have a very large 'reference only' note on every installation drawing which includes a statement that 'attachment to concrete requires SEOR review/approval before installation of any equipment'
I also have a PROFIS report which indicates that due to the condition of the floor (very thin) and reinforcement (WWF only) there is only one Hilti anchor that can work. My gut also tells me that in this particular installation, successful install and service without any modification to the floor of this building is highly unlikely. Since I am not a structural engineer, I do not believe I am qualified to calculate whether or not my gut feeling is correct- because if I put anything on paper, I do not believe I will be able to prevent my 'estimate' calculations from becoming a certification so to speak.
Of course, my PM is trying to avoid the monetary and time cost of SEOR review, and wants me to release my PROFIS report, specify the attachment myself, and quit complaining.
As neither a structural nor professional engineer, I am very uncomfortable both with this particular project and with the precedent this would set. So here is the question- is there ANY indication in any of the applicable codes (IBC? ASIC?) which offers some direction on what engineered features do or do not require SEOR approval when a building is modified or occupancy changed? I have pored over every code that I know to try and find, with no help on this issue.
Any help that any of you could offer in clarifying this issue would be greatly appreciated.
