separately stress relive after hot forming
johnytringuyen
7
Dear Gents,
could you pls advice
1. Do we need require separately stress relive after head hot forming of vessels
2. Which is best separately heat treatment require after hot forming
3. Is it necessary separately normolization after hot forming if base plate has been normolise.
Johny
We need more information.
What material specification are you using?
What is the thickness of the heads?
What temperature were they formed at?
More important what construction are you using for the above?
Dear Gents,
The vessels is designed as per Asme XIII div 2
Please do not duplicate this post with what you posted in the Boiler and Pressure vessel engineering forum.
